NAS to NAS Synchronization
JockeSve
I'm planning to do a full backup (+6TB data) before replacing (upgrading) disks on my NAS540.
Will Synchronization to another NAS540 preserve all file/folder/share attributes (all dates, security, ...)?
If not, is there another way to save all attributes (most importat at this point is file/folder date(s))
#NAS_July_2020
I think synchronization will preserve all the files and since you have mentioned you are planning to do a full backup, I suggest using Publish would be a better choice.0
AFAIK the 'Mirror' option removes all 'orphan' files (not on source NAS) whilst 'Publish' just copies everything so I don't see why not use 'Mirror'.
I'm just a bit worried about date attributes (created, modified & accessed) on synced files.
The last option is to use 'Robocopy' with "/DCOPY:DAT /COPY:DAT" options...
A quick update:
Zyxel's 'Mirror' and 'Publish' Doesn't preserve dates for folders...
Some weird "bug"
Files seems to be handled properly.
Luckily Robocopy can handle and preserve both dates correct.0
- 588 USG FLEX H Series
- 476 News and Release
