Can I control or how do I tell which node I am connected to (Multy X and/or Multy Mini)
T_ZyxelUK
How can I find out which Multy X node I am connected to on my network or if I am connected to my Multy Mini.
If you can check this, can I force a device to join a specific device upon arrival?
T
#Multy_Jul_2020
T
#Multy_Jul_2020
Multy support Roaming feature, which can help your device to select a better connection with nodes.
Please refer to the link for detail information :
https://kb.zyxel.com/KB/searchArticle!viewDetail.action?articleOid=016610&lang=EN
Devices will select the connection itself, and that is the behavior of the wireless device, Multy cannot force the connection on them.
thanks for the response Eric.for the second part of the question, ifs there a way i can check which Multy i am connected to though?Thanks,T0
Dear Sir,
You can download WiFi analyzer on your Andriod phone, it can provide the BSSID of the wifi that you connected, and you can base on the BSSID to check which Multy you connected.
https://play.google.com/store/apps/details?id=com.farproc.wifi.analyzer&hl
Best Regards,
Eric0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 908 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
