Multy U time switch
ra1967
Dears,
Is there any time switch available for Multy U ?
I would like to deactivate WLAN over night.
If not,
1. how could that be realized ? Smarthome available.
2. Is there any plan to realize it ?
3. Is there any other access point available with that feature ?
Many thanks for any feedback
ra1967
If not,
ra1967
Yes, you can power on the Multy at the morning, and it will broadcast the wifi after it is on.0
Dear Sir,
Multy cannot set a schedule for wifi. I don't have plan for this feature in the future.
I will recommend Armor Z2(NBG6817), it can provide you the feature that you need.
https://www.zyxel.com/products_services/armor_z2.shtml?t=p
Best Regards,
Eric
Thanks for the answer.
Is Multy U reconnecting on itself automatically if I turn off the power over night (first Multy U connects per LAN and not per WLAN to the router) ?
Many thanks for further advice
Greets
ra19670 -
I don't understand what you mean, can you describe more detail of your question?
If you unplug the power of Multy U overnight, it will be off, and it is no possible that it will reconnect or reboot without the power.
I'm sorry for the misunderstanding.I would like to unplug the power in the evening and would like to plug in it in the morning.The question is: Will Multy U reconnect to the network and provide the WLAN in the morning, if I plug in the power.0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 908 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
