GS1900-8HP/10HP - automatic password reset?
FriBi
FriBi Posts: 2 image  Freshman Member
edited August 2022 in Switch
We've have a GS1900-8HP and a -10HP in use. From time to time the items reset their password by their own! Means, when I try to log in with the user defined password it does not work anymore. Instead the standard password is active. Also the factory setting is in use. Why? There is no access to the hardware for anybody. So noone could have pressed a reset. Nevertheless the items are on factory setting. Why?
  • Kim
    Kim Posts: 37 image  Freshman Member
    Did you save your configuration after configuring it?
  • FriBi
    Sure. Did the settings. Loged out. Loged in again. Password and settings as set. After a few days/weeks factory settings... No clue, what is the base for this?
  • Sakura_T
    Sakura_T Posts: 101 image  Ally Member
    @FriBi
    I think what @Kim said is to press "save button" after you did the setting, did you?
