Does Multy U (WSR30) support Daisy Chain?
Zyxel_Support
Posts: 436 Zyxel Employee
Multy U (WSR30) is
true mesh system which combined Daisy Chain and Star Topology.
Daisy Chain
Star Topology
True Mesh
Daisy Chain
Star Topology
True Mesh
Hi, you said it's supported BUT we can't activate the daisy chain mode ! also in the manual page 5 it's written that the multi U don't support !! so ... can we or not activate this mode ?0
Dear Sir,
Multy U supports multiple connections with other nodes, which means Multy U will build the connection with every node that it can receive signal with.
That's why it doesn't have the option for Daisy Chain because it will build the path with every nodes base on the location of that Multy.
In general, the Multy U supports the combination of Daisy Chain and Star topology at the same time.
Best Regards,
Eric
i have recently installed a multy u system (3 devices) at home, the setup wen’t smoothly and i activated bridge mode as i already have a router by my isp.
The problem is, it seems that they can’t work in daisy chain mode, each node needs to connect to the main multy u, or they won’t work at all, this is not very practical as my house is quite long, and i need the nodes to be able to connect to each other. On your faq, you say daisy chain is automatic.. but when i launch a test, the only test running are between the main node and the others, not the secondairies between them.
This seems to proove that daisy chain is not working ... any advice? Perharps a firmware update could solve that.
thanks0 -
i will answer to myself as i found the solution: to force it work, i had to put the third device far far away, so that it had absolutely no chance to connect to the main hub, and then, after i restarted the system, it worked and connected in daisy chain. You still can’t see it when you diagnose, but it works anyway.
Regarding the main question about the best topology.
My house has 5 rooms and a large covered terrace that we use in the summer. Let's say 6-7 rooms in total.
I am privileged as I have a roof and have erhernet cables run through the roof and can connect the multys with ethernet cables for better and stable results.
Which topology is best for wired connection. Should I connect them in a chain arrangement starting from the router or as a star with the router in the center?
I would suggest to use daisy chain instead of star.
Once there is the disconnection between the devices, using daisy chain would make it easy to find out the problem.
You can easily know which device gets the problem and reboot the device.
- 396 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 86 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 916 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 912 Nebula FAQ
- 419 Security FAQ
- 237 Switch FAQ
- 207 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
