NSA 325 v2: Volume nearly full and files not deletable
myZyxel
one of my 325 v2 has a problem with a volume which is nearly fully used.
I can't delete any file. Volume is mounted to a Windows 10 client.
What can I do?
You can close this discussion.My "solution": I deleted the volume, created a new one and everything is fine again.0
Wondering, did you have the recycle bin enabled? I wonder if deletion in that case might be a copy to the recycle bin, followed by a delete of the file. In which case you need diskspace to delete a file.
- 588 USG FLEX H Series
- 476 News and Release
