How do I know my extender is working?
Tiia
I bought and set up WRE2206, but there's no other light besides the blue power light. My router has WPS button so I think the set up went fine. Do I need to do anything after the light stops blinking? Should the whote lights be on?
Sorry "white lights be on" meaning the strength and connected devices.0
@Zyxel_Support hi! Could you help me?
Hi @Tiia
Once the WRE2206 connects to your Router via the WPS button, the Signal Strength light should on. If it cannot connect to your Router, you might have to access to WRE's WebGUI to select the wifi signal manually.
Please refer to the quick start guide,
https://www.zyxel.com/support/download_landing/product/wre2206_18.shtml?c=gb&l=en&pid=20141009130001&tab=Quick_Start_Guide&pname=WRE2206
Best Regards,
Eric0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
