zyxel nas540 bootloop after unsuccesfull debian kernel upgrade
greenwitch
I had bad flash of newer kernel on Debian.
I had log like following:
booting kernel of type uimage from /dev/nand0.kernel2.bb
Verifying Checksum ... Bad Data CRC
Failed.
booting kernel of type uimage from /dev/nand0.kernel1.bb
ERROR: out of memory
Failed.
I have managed to upload new kernel.
Now I dont know why I am able to boot from second kernel. From kernel 1 I have this issue:
Failed.
Failed.
From kernel 2:
[ 20.364539] VFS: Cannot open root device "ubi0:rootfs" or unknown-block(0,0)
[ 20.371618] Please append a correct "root=" boot option; here are the available partitions:
[ 20.380009] 1f00 256 mtdblock0 (driver?)
[ 20.385089] 1f01 512 mtdblock1 (driver?)
[ 20.390173] 1f02 256 mtdblock2 (driver?)
[ 20.395252] 1f03 10240 mtdblock3 (driver?)
[ 20.400336] 1f04 10240 mtdblock4 (driver?)
[ 20.405415] 1f05 112640 mtdblock5 (driver?)
[ 20.410498] 1f06 10240 mtdblock6 (driver?)
[ 20.415576] 1f07 112640 mtdblock7 (driver?)
[ 20.420660] 1f08 6144 mtdblock8 (driver?)
[ 20.425738] 0800 2930266584 sda driver: sd
[ 20.430389] 0801 2930265088 sda1 81ae083b-429a-4768-9f2c-a38c8ddeb287
[ 20.437478] 0810 2930266584 sdb driver: sd
[ 20.442122] 0811 2930265088 sdb1 eceb1340-7ebb-477c-8594-46d3d3ca0f4c
[ 20.449210] 0830 1953514584 sdd driver: sd
[ 20.453853] 0831 514048 sdd1 00000000-0000-0000-0000-000000000000
[ 20.460940] 0832 1952997952 sdd2 00000000-0000-0000-0000-000000000000
[ 20.468025] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
when kernel two is booting default commandline is like following:
commandline: console=ttyS0,115200n8, init=/etc/preinit pcie_gen1_only=yes mac_addr=,, ip=dhcp root=ubi0:rootfs ubi.mtd=2,2048 rootfstype=ubifs rw noinitrd mtdparts=spi0.0:256k(uloader)ro,512k(barebox)ro,256k(env);comcertonand:10M(config),10M(kernel1),110M(rootfs1),10M(kernel2),110M(rootfs2),-(reserved) usb3_internal_clk=yes
arch_number: 1094
arch_number: 1094
my printenv:
Barebox-C2K >/ printenv
locals:
PATH=/env/bin
ip=dhcp
kernel_loc=nand
rootfs_loc=nand
uloaderimage=microloader-c2kevm.bin
bareboximage=barebox-c2kevm.bin
mfg_kernel_img=uImage_MFG
mfg_rootfs_img=rootfs_ubi.img_MFG
rootfs_type=ubifs
rootfsimage=root.ubifs-128k
kernelimage_type=uimage
kernelimage=uImage
spi_parts=256k(uloader)ro,512k(barebox)ro,256k(env)
spi_device=spi0.0
nand_device=comcertonand
nand_parts=10M(config),10M(kernel1),110M(rootfs1),10M(kernel2),110M(rootfs2),-(reserved)
rootfs_mtdblock_nand=1
autoboot_timeout=3
bootargs=console=ttyS0,115200n8, init=/etc/preinit pcie_gen1_only=yes mac_addr=,,
next_bootfrom=1
curr_bootfrom=1
kernel_mtd_1=4
sysimg_mtd_1=5
kernel_mtd_2=6
sysimg_mtd_2=7
MODEL_ID=B103
globals:
locals:
PATH=/env/bin
ip=dhcp
kernel_loc=nand
rootfs_loc=nand
rootfs_type=ubifs
kernelimage=uImage
spi_device=spi0.0
autoboot_timeout=3
next_bootfrom=1
curr_bootfrom=1
kernel_mtd_1=4
sysimg_mtd_1=5
kernel_mtd_2=6
sysimg_mtd_2=7
MODEL_ID=B103
globals:
I am not able to saveenv.
after every boot
Can somebody help me?
I think I need proper bootsargs
When I boot from command line:
bootm /dev/nand0.kernel2.bb
I can boot with argument I provide in bootargs
Adam
bootargs="console=ttyS0,115200n8 pcie_gen1_only=yes usb3_internal_clk=yes init=/sbin/init root=/dev/sda2 rootfstype=ext4 rootdelay=5 panic=5"
saveenvbootm /dev/nand0.kernel2.bbmagic happens. But NAS is still rebooting itself after some time. But we have progress and I boot to debian. In parallel of course old disk with debian crashed... not easy
How long is 'after some time'?Can you remember if the flash partitions were accessible from Debian?0
- 588 USG FLEX H Series
- 477 News and Release
