Multy X set up issues
feastofblaze
I've been spending an afternoon or so trying to set up a Multy X mesh network and I'm about ready to give up.
#Multy_Aug_2020
I seem to be able to connect one Multy X to my home router fine, but as soon as I connect another Multy to the primary one things start to go wrong. The network disappears every 5 minutes or so, and the white LED flashes on the primary Multy while the secondary one eventually goes solid red. I have followed the instructions on the app, the devices are both up to date and have been rebooted multiple times, the Multy's are the right distance apart... I've tried starting from scratch. I have emailed support but I thought I'd ask here too.
Any help would be massively appreciated!
#Multy_Aug_2020
Do you mean that you did install the second Multy successfully, but the second multy would disconnect every 5min?
You can try to connect them with Ethernet as a test. see if the issue would still happen again.
You can also send feedback from the App for help.
Hi Guys,
Has anyone found certain symbols or "special Characters" on certain mobile phones will not work on password setup, found this out today, tried inputting ISP password on my Hauwei, just would not allow me to input = sign...?? then I tried the same setup but on an iPhone and it accepted the = symbol and setup, added the Mini and works great,.... strange ??0 -
I do not have Huawei mobile.
So far, we do not met the symptoms on my iPhone, everything just works fine.1
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
