DHCP Settings from the CLI and/or an API?
Peter Tselios
I have a VMG1312-B10D VDSL Router. Router's firmware is the V5.13(AAXA.5)C0
But by CLI has only the following commands:
. : [ [[ alias bg break cd chdir command continue echo eval exec
exit export false fg getopts hash help jobs kill let local printf
pwd read readonly return set shift source test times trap true
type ulimit umask unalias unset wait
So, how do I access the router's commands?
I haven't changed a lot in the device, so, I didn't need to access the CLI. Now, it's time to start some more advance configuration.
The first thing I need is to modify it's DHCP settings from settings that are only via the CLI.
Normally, CLI commands are used for debugging usage,If you want to configure DHCP settings, it is suggested to change the settings via GUI.1
The settings on the gui are not very helpful.For example, I don't see anywhere settings for next server, or delay or ... or ...0
Hi @Peter Tselios
There is a user guide for the VMG1312-B10D available at ftp://ftp.zyxel.com/VMG1312-B10D/user_guide/ which should give you some help.
It says:
and you change the setting on the LAN Setup page of the GUI.
I hope that this helps. Merry Christmas and a Happy New Year.
Tony0 -
Hi @Peter Tselios
To get to LAN Setup in the GUI, you have you look under Network Setting and then Home Network.
You will then get the following screen.
I hope that this helps. Merry Christmas and a Happy New Year,
Tony0 -
Hi @Peter Tselios
Here is another extract from the user guide that might help you.
Tony0 -
Hi @Peter Tselios
Last manual extract for you that might help:
Tony0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 299 Service & License
- 482 News and Release
