Zyxel NSA325v2 USB drive availability/mount
Can't answer, always gives me error.0
I have three disks attached to the NAS, if I do cat /proc/mounts, they seem to be here:/dev/sde1 /e-data/a35de5893a858e7a94bbbee375814f29
/dev/sdc1 /e-data/4b057828951167c27e50544d8404a891
/dev/sdd1 /e-data/c951f3cc780eb9ae37e5dd1e6b11013cBut don't know how to translate it to auto-mounting (because all of them are unmountd0 -
Didn't work; I booted and WD still not detected until I enter configuration page
I have three disks attached to the NAS, if I do cat /proc/mounts, they seem to be here:/dev/sde1 /e-data/a35de5893a858e7a94bbbee375814f29 tntfs rw,relatime,uid=99,gid= 0,umask=00,nls=utf8,case_sensitive,nocache,errors=continue,mft_zone_multiplier=1 0 0/dev/sdc1 /e-data/4b057828951167c27e50544d8404a891 tntfs rw,relatime,uid=99,gid= 0,umask=00,nls=utf8,case_sensitive,nocache,errors=continue,mft_zone_multiplier=1 0 0/dev/sdd1 /e-data/c951f3cc780eb9ae37e5dd1e6b11013c tntfs rw,relatime,uid=99,gid= 0,umask=00,nls=utf8,case_sensitive,nocache,errors=continue,mft_zone_multiplier=1 0 0
When the disks show up in /proc/mounts, they are mounted. But apparently they are not shared. Do the mounts show up in /etc/samba/smb.conf?
I think they do:[Series]path = /i-data/2dc65cad/PelÃculasguest ok = yesfollow symlinks = yesstrict allocate = yesvfs objects = recyclerecycle:repository = recyclerecycle:exclude = .test.permission.file.*recycle:directory_mode = 0777recycle:subdir_mode = 0777recycle:keeptree = yesrecycle:versions = yesrecycle:touch = yesrecycle:touch_mtime = norecycle:maxsize = 0[Disco 9-WD]path = /e-data/4b057828951167c27e50544d8404a891guest ok = yesfollow symlinks = nostrict allocate = no; NO Action-log or Recycle-Bin[Disco 7-S]path = /etc/zyxel/storage/sysvol/.system/autoshare_sata/Disco 7-Svalid users = "admin"follow symlinks = yesstrict allocate = yes; NO Action-log or Recycle-Bin[Disco 0-L]path = /etc/zyxel/storage/sysvol/.system/autoshare_sata/Disco 0-Lvalid users = "admin"follow symlinks = yesstrict allocate = yes; NO Action-log or Recycle-Bin0
Edit: this is after entering config page (didn't remember I already did it). If I don't enter this page, "Disco9-WD" (WD disk) doesn't appear.0
There is a striking difference between "Disco9-WD" and the other two:path = /e-data/4b057828951167c27e50544d8404a891path = /etc/zyxel/storage/sysvol/.system/autoshare_sata/Disco 7-Spath = /etc/zyxel/storage/sysvol/.system/autoshare_sata/Disco 0-L
Only the Disco9-WD share points to the mountpoint. The other to point to something else. A symlink to the mountpoint, probably. Did you configure the disks differently? The credentials are different too.
Sorry for being delayed, but the change in the forum made me lose the thread.
I tried to reset the nas (I thought it wouldn't lose the info), and now I can't access my previous folders anymore; restored the settings backup and now I can access one of the disks, but not the other.
I am trying to recover the info with easeus data recovery, but is it not any way to access previous files and folders?
- 441 Beta Program
- 210 Nebula Ideas
- 540 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
