How to open NSA325 v2
vladm
vladm Posts: 1 image  Freshman Member
Hello.
NSA325 v2 : the On/Off switch is loose. The fixation must probably be glued again. My (easy?) question : how to open / disassemble the outer plastic case. There are 2 screws underneath, 4 at the back (seems for the ventilator), but the case still cannot be disassembled.
