[Solved] gs1200-8 management
Hi all,
it's the first time I setup a managed switch and I'm having some headaches.
1) I cannot upgrade the firmware. My device is running version V1.00 ABME.5 C0 and it refuses to upgrade complaining that GS1200-8_V2.00(ABME.0)C0.zip, downloaded many times from official site, is not the right one. I don't think this is relevant in my configuration, but it's weird.
2) Despite my setup is working well, I'm unable to access my zyxel
from lan. I have to plug a cable into port 1 to manage the switch that
is not the wanted behaviour.
This is my configuration
Zyxel switch has IP 192.168.165.3, which is in my lan range.
A RaspberryPi plugged into port 3 as router with 3 interfaces:
- eth0 192.168.100.1 (why this ip works and 192.168.165.xxx doesn't???)
- eth0.62 dhcp (wan)
- eth0.165 bridge eth0 eth0.165 static ip 192.168.165.1 (lan) cable to RaspberryPI on port 3
Port 1 unassigned in order to manage the switch looking for a better solution, port 2 wan cable, port 3 Raspberry, ports 4-8 lan cables.
Switch setup (vlan 254 it's a failed test) is in following picture
What I'm wrong?
Thank in advance
My kind regards
DDep
Hi @Trebbes,
Welcome to Zyxel Community!
Regarding the inquiry,1) I cannot upgrade the firmware. My device is running version V1.00 ABME.5 C0 and it refuses to upgrade complaining that GS1200-8_V2.00(ABME.0)C0.zip, downloaded many times from official site, is not the right one. I don't think this is relevant in my configuration, but it's weird.I've made a local test by downloading the latest version V2.00 from our global website, it's downloadable and can successfully upgrade GS1200-8 from V1.00 ABME.5 C0 to V2.00(ABME.0)C0.
More likely the event is more related to the file is not download completely or wrong file.
Please refer to the attached file for the FW zip file, you'll need to unzip the file first, the firmware file name is GS1200-8_V2.00(ABME.0)C0.bin and the correct size should be 672 KB.2) Despite my setup is working well, I'm unable to access my zyxel from lan. I have to plug a cable into port 1 to manage the switch that is not the wanted behaviour.Just would like to inform that current GS1200-8 V1.00 ABME.5 C0 doesn't support management VLAN, therefore you'll need to upgrade to the latest version V2.00(ABME.0)C0.
After the firmware upgrade, please go to management and change "Management VID" to your preferred VLAN, eg. 165.
Hope it helps.
Jonas,0
I partially answer by myself. With the same configuration a TP-Link switch is working as expected so maybe my Zyxel device, by bad luck or by design, is faulty.As I can't even upgrade the firmware Is there any other test to do before send it back to Amazon?My kind regards0
Hi @Trebbes,
Hope it helps.
Jonas,0 -
Many thanks Jonas for your answer.Shame on me!! 'you'll need to unzip the file first' is the relevant part of the topic.Now I can manage the switch within the lan.Sorry for the noise.My best regards1
Hi there,
sorry it seems I am the only one who dont get it work tried for hours and hours.
First I connect untagged to configure. Afterwards I want to use my tagged VLAN (99 Management).
Tagged only 99 & others.
Routers (opnsense goes on port 1):
1: set to dhcp
2: VLAN 99 port 1: tagged,
3: pvid =3 (not 99) (port1)
4: pvid 99 (port 7 for management client)
5. Managment VLAN 99
Afterwards client on port 7 gets an ip an can access the router. Switch is not possible to reach (have to reset)
VLAN does definetly work (tried several devices)
What am I doing wrong (of course latest firmware on switch).
I would be very greatful for all help0 -
I managed to resolve that… It was the router not the switch…
- 435 Beta Program
- 175 Nebula Ideas
- 422 USG FLEX H Series
- 297 Security Ideas
- 273 Service & License
- 418 News and Release
- 89 Security Highlight
