SNMP or other solution for monitoring XGS1210-12 ?
Hi, I just acquired 2 XGS1210-12 switches. It's a very good product
with a very good quality/price ratio, but it's a shame not to have any
solution to monitor it.
Apart from the web
interface, it's not possible to use an external monitoring solution
(nagios, zabbbix, prometheus...) to get information about the switch
status, or to get traffic statistics.
Do you think you will bring these features one day via a firmware update?Thanks
Hi @bvivi57 ,
First of all, thanks for choosing XGS1210 for your network.XGS1210 desktop switches are intended for Home/SOHO users with just a few other networking devices in their network.A simple management tool such as web GUI is sufficient to setup such network easily for most cases.As external monitoring tools are mostly used for small-medium networks, SNMP feature is supported by more advanced Smart Managed Switches such as the GS1900 series.Hence, there’s currently no plan to add this to the desktop Switch series for now.0 -
Have you contacted the support yet?bvivi57 said:Hi, I just acquired 2 XGS1210-12 switches. It's a very good product with a very good quality/price ratio, but it's a shame not to have any solution to monitor it.Apart from the web interface, it's not possible to use an external monitoring solution (nagios, zabbbix, prometheus...) to get information about the switch status, or to get traffic statistics.Do you think you will bring these features one day via a firmware update?
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
