USG FLEX 100W WLAM DHCP
Lost1
Lost1 Posts: 33 image  Freshman Member
edited April 2021 in Security
I cannot find where to setup the DHCP for the WLAN.
Ethernet was fine but where are the DHCP Setting for the wireless?
I know I've missed it somewhere!!
Thanks!
  • Lost1
    I see under wireless the only settings are Outgoing Interface which have choices of LAN1, LAN2 & DMZ.....am I missing on option so it will not be part of those interfaces?
    PeterUK Posts: 4,217 image  Guru Member
    The DHCP setting are in interface like LAN1 when you setup the SSID for no untag VLAN ID 1 you set VLAN support to off and outgoing interface LAN1, if setting up a VLAN on base port LAN1 for the SSID you set VLAN support to on.
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,350 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Hi @Lost1
    You can choose Outgoing Interface (e.q. lan2) of WLAN.
    And navigate Configuration > Network > Interface > Ethernet > Edit interface(e.q. lan2) DHCP IP range.
  • Lost1
    Thanks!  Yes that's my issue/question...I want to use Lan1 & Lan2 for different things other than Wlan.  It's like you only get two different networks when you use Wlan wereas my old zyxel had Lan1, Lan2, Wlan, & DMZ all with their own subnets.
    I just hate giving up Lan2 or Lan1
    edited February 2021
    Make a new zone and a VLAN with that zone for the WLAN.
