NAS 540 - Admin share deleted
Celestino
Celestino Posts: 2 image  Freshman Member
Hi, I deleted the admin folder by mistake and now it appears with "lost" status under the Shared Folders of the Control Panel. Is it possible to recover or delete it, so a new share can be created?
Thank you in advance for your help.
  • Mijzelf
    Mijzelf Posts: 3,051 image  Guru Member
    AFAIK it's not possible to remove the admin share using the firmware capabilities. You can delete the directory using shell access, but that doesn't remove the share (share as in: configuration line in in smb.conf).
    So you can put the directory back (mkdir /i-data/sysvol/admin), or live with the 'lost' status.
  • Celestino
    Thanks a lot!
