NBG6615 - firmware V1.00(ABMV.4)C0 problem
xWing
in Home Router
Hi people,
After update V1.00(ABMV.4)C0 firmware, my router cannot obtain IP adress, Subnet Mask and Gateway.
There is only ZERO numbers. 0.0.0.0
DNS servers are OK, I see IP adress.
Connection Type says "Getting IP from DHCP server..." in Status windows
WAN is set to DHCP client
Do someone have same problem with latest firmware V1.00(ABMV.4)C0 ?
I will be very thankful for any solution.
Hello @xWing
I don't know if this will help, but the release notes at https://download.zyxel.com/NBG6615/firmware/NBG6615_V1.00(ABMV.4)C0_2.pdf say
"2. To upgrade the firmware NBG6615 V1.00(ABMV.4)C0 or later, make sure to upgrade V1.00(ABMV.3)C0 firmware in advance."
I hope that this is helpful.
Kind regards,
Tony0 -
tonygibbs16 said:make sure to upgrade V1.00(ABMV.3)C0 firmware in advance.Yes, I am sure that it had V1.00(ABMV.3)C0 firmaware.I read it before the update.1
Hi @xWing,
please try a reset of router under Patch 4.
Press reset button at the rear for 10 seconds to delete current config and re-setup the router.
Kind Regards,
Tobias0 -
Unfortunately, it didn't help.I wrote to support and they sent me older firmware V1.00(ABMV.3)C0_20200313 and it works.But I do not understand, why newest frimrware V1.00(ABMV.4)C0 does not work for my router
Hi xWing,
can you send me Support Ticket Number please?
I´ll make sure that you will get a working Patch 4 or higher in future.
Thanks.
Kind Regards,
Tobias0 -
But, my comunication with support is in slovak and czech language.Can you speak czech or slovak language ? ;-)Or try some translator. ;-)
Hi @xWing
Perfect, I can confirm my colleague Jan did perfect escalation already to our dev team to get a bug fix.
You´ll hear from them I think around end of week a status update.
Thanks.
Kind Regards,
Tobias1 -
No problem,Thank you for your interest.
My comunication with support is in slovak and czech language.Can you speak czech or slovak language ? ;-)But try some translator.Ticket #2021990
- 588 USG FLEX H Series
- 477 News and Release
