ZyWALL USG 300 USB Ports
link000
link000 Posts: 34
edited April 2021 in Security
Hello. The router has 2 USB ports. If you connect 2 USB flash drives to both ports, then only one or none at all is available for logging. Is that how it should be? And what is the maximum amount of USB flash that can be used to write logs?
Security Highlight
