ZyWALL USG 300 USB Ports
Hello. The router has 2 USB ports. If you connect 2 USB flash drives to both ports, then only one or none at all is available for logging. Is that how it should be? And what is the maximum amount of USB flash that can be used to write logs?
The first question disappears. Found the answer here: https://community.zyxel.com/en/discussion/4134/log-and-backup-to-usb
I found the answer to the second question in the same place. Thanks to all.
- 588 USG FLEX H Series
- 477 News and Release
