USG110 Inactive WAN not marked as inactive
Martin_Kuchar
Martin_Kuchar Posts: 38
edited April 2021 in Security
latest firmware, 2 wan ports, auto fallback, connectivity check..
Today, we have problem on wan1 (ISP down, no internet). USG auto closed wan1 and opened wan2. Internet is OK, no problem with network. BUT although in System Log/Connectivity Check is clearly stated "The wan1 routing status is set to DEAD by connectivity-check" and "The link status of wan1 interface is inactive.", on Dasboard the wan1 is marked as OK and the same in Monitor->System Status->Interface Status - "1000M/Full" instead of something like "Inactive"
Any ideas?
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 826
    50 Answers 500 Comments Friend Collector Second Anniversary
    Hi @Martin_Kuchar
    Thank you for your suggestion.
    Currently, we don’t support this feature.
    We will put it into our future development evaluation.
    Thanks.
  • USG_User
    USG_User Posts: 365
    5 Answers First Comment Friend Collector Fifth Anniversary
    Maybe the ethernet connection to next hop, e.g. Proxy Server etc. still works ... and the fail is only behind the next station.
  • Martin_Kuchar
    Yes, this is the case. Fiber GW between USG and Internet is online. But when connectivity check inactivated the interface, admin should know about this. Log is not sufficient. When inteface is disabled by Connectivity check, it should be clearly marked as Inactive at least on the Dashboard graphics!
  • kyssling
    kyssling Posts: 102
    First Comment First Answer Friend Collector Fifth Anniversary
    Hi all, please add this feature ... Information about inactive interface is most important ! (port is OK, but internet from provider is KO) ...
Security Highlight
