NSA-325 v2 with FW V4.80(AALS.1): Should I update to V4.81(AALS1)?
myZyxel
Should I update and is there any problem with installed Tweaks an Metarepository?
Kind regards
You can find the releasenotes here: ftp://ftp2.zyxel.com/NSA325/firmware/Tweaks and MetaRepository will be fine. It won't hurt to disable them during the update, though.
Worked like a charm. Thanks.
- 439 Beta Program
- 2.8K Nebula
- 203 Nebula Ideas
- 522 USG FLEX H Series
- 330 Security Ideas
- 49 Wireless Ideas
- 289 Service & License
- 4.4K FAQ
- 98 Security Highlight
