What are GS1900-24E firmware 2.6(AAHC.3) ssh console commands?
EerWie
EerWie Posts: 4 image  Freshman Member
edited August 2022 in Switch
Where could I find command list?
  • Zyxel_Jonas
    Zyxel_Jonas Posts: 313 image  Zyxel Employee
    25 Answers First Comment Friend Collector Fifth Anniversary
    Hi @EerWie,
    I would like to inform that GS1900 series are smart managed switch which means you may only configure the switch via web GUI. If you want to configure the switch using command line, you'll need a manage switch like; GS2220 series.
    Hope it helps.
    Jonas,
  • EerWie
    Actually you could log in with ssh if enabled. So there should be the list of used commands somewhere.
    BR
  • bensegar
    bensegar Posts: 2 image  Freshman Member
    So what is the command list?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,680 image  Zyxel Employee
    Hi @bensegar,
    Welcome to Zyxel community!
    Since GS1900 series is a smart managed switch which does not support CLI command to configure.
    You may only configure the switch on web GUI.
    If you want to configure the switch using command line, you'll need a manage switch like; GS2220 series..
    Zyxel Melen
  • Jhonwick
    Jhonwick Posts: 4 image  Freshman Member
    I check my GS1900-8HP and find some commands can use, you can check my attachment.
    But GS1900 could not configure via CLI, just like Jonas and Melen said.
