Slow WiFi/LAN bridge speed.
Dodlee
Hi
I have a ZYXEL VMG3925-B10C. My computer is currently 2 feet away from it. I am connected via 5GHz AC at full signal. Windows reports the connection is at 866 mbps. I access another computer that is connected to the ZYXEL via ethernet. Speed is terrible, about 90mbps, no where near 866. I disconnect from WiFi and connect via ethernet. I test the speed to the other computer again, I get the full 1000mbps. Why is the wifi so slow? And how do I fix it?
NVM, after doing some research it seems that's all the device is capable of due to software based packet steering. Basically, it's a pile of garbage. So looks like I'm going to have to fork out for a decent AP, disable the Wifi on this useless rubbish and plug it in via ether net to get anything like reasonable Wifi speeds.0
Hello @Dodlee
Do you know what firmware your VMG3925-B10C is running?
ftp://ftp.zyxel.com/VMG3925-B10C/firmware/ shows that the latest firmware is V5.13AAVF12.C0 is the latest from 2018/19.
Kind Regards,
Tony
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
