NAS326 defaults after restart or shutdown
znas4home
NAS326 after reboot or shutdown defaults all settings and passwords etc.
Every time after reboot or shutdown I need to set new password and set it up again and again.
Is this by design behavior or there is solution?
I must admit that I don't know much about ubi's. One of the blocks is in the middle of your config partition:nand_read_bbt: bad block at 0x0000004400000x000000400000-0x000000e00000 : "Config"but I don't know if the filesystem on config should be able to handle that. Bad blocks in nand are normal, and somehow it's handled, but I don't know if a bad block on any place can be handled.If the 'reset_and_reboot' script (executed as root!) doesn't solve your issue, and you box is still under warranty, I'd RMA it.
That is not by design. The configuration should be stored on a flash partition. If that fails, then the configuration is stored on the mountpoint of that partition, which is on a ramdisk, and so volatile.It might help to do a factory reset (press the reset button on the back for 25 seconds, until it has beeped 3 times), which puts a new filesystem on that partition.0
Unfortunately factory reset didn't help.When I look into dmesg I found some information about NAND bad blocks:--------dmesg cut--------------armada-nand f10d0000.nand: Initialize HAL based NFC in 8bit mode with DMA Disabled using BCH 4bit ECC
NAND device: Manufacturer ID: 0xc2, Chip ID: 0xda (Macronix NAND 256MiB 3,3V 8-bit), 256MiB, page size: 2048, OOB size: 64
Bad block table found at page 131008, version 0x01
Bad block table found at page 130944, version 0x01
nand_read_bbt: bad block at 0x000000260000
nand_read_bbt: bad block at 0x000008740000
nand_read_bbt: bad block at 0x00000e940000
7 ofpart partitions found on MTD device armada-nand
Creating 7 MTD partitions on "armada-nand":
0x000000000000-0x000000200000 : "U-Boot"
0x000000200000-0x000000400000 : "U-Boot env"
0x000000e00000-0x000001d00000 : "Kernel-1"
0x000001d00000-0x000008700000 : "RootFS-1"
0x000008700000-0x000009600000 : "Kernel-2"
0x000009600000-0x000010000000 : "RootFS-2"
m25p80 spi0.0: unrecognized JEDEC id ffffff
<...skip..>UBI: attaching mtd2 to ubi2
UBI: scanning is finished
UBI error: ubi_read_volume_table: the layout volume was not found
UBI error: ubi_attach_mtd_dev: failed to attach mtd2, error -22
UBIFS error (pid 1663): ubifs_mount: cannot open "ubi2:ubi_config", error -19
UBI: empty MTD device detected
UBI: attached mtd2 (name "Config", size 10 MiB) to ubi2
UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
UBI: good PEBs: 79, bad PEBs: 1, corrupted PEBs: 0
UBI: user volume: 0, internal volumes: 1, max. volumes count: 128
UBI: max/mean erase counter: 0/0, WL threshold: 4096, image sequence number: 243037217
UBI: available PEBs: 36, total reserved PEBs: 43, PEBs reserved for bad PEB handling: 39
UBI: background thread "ubi_bgt2d" started, PID 1679
UBIFS: default file-system created
UBIFS: background thread "ubifs_bgt2_0" started, PID 1684
UBIFS: mounted UBI device 2, volume 0, name "ubi_config"
UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
UBIFS: FS size: 3301376 bytes (3 MiB, 26 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
UBIFS: reserved for root: 155931 bytes (152 KiB)
UBIFS: media format: w4/r0 (latest is w4/r0), UUID AE4331BC-9234-4C1B-8557-693926C9FD74, small LPT model
-------dmesg cut-------Could it be the reason?
I had to RMA it. Replacement device has 7 bad blocks in nand, but at least it saves configuration. Thank you!0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 908 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
