Blinking white light on NAS326
JJA
Good morning,
I recently bought this NAS with a HDD Seagate ST3000DM007.
If I turn on the NAS with no HDD on its bays it boots until the end.
But if I try to boot it with the HDD inside any of its bays, the NAS starts blinking a white light on the power button.
Also happens, with the NAS booted, if I insert the HDD, all suddenly stops (fan also) an the white blinking light is back.
Could you please help me with this issue?
Best regards
Best regards
Hi,There is NAS compatible list on the Zyxel website,The ST3000DM007 in not in the compatible list, maybe you should try other model of disk.You could consider the disk in the compatible list.
Thank you workinto, I will purchase another HD and come back to you with the result!0
That's not a compatibility list, but a 'Verified Hard Disk List'. Sata is sata, so any sata disk is supposed to work. The list only shows the disks which were tested. As there are no fails on that list, you can assume every disk the ZyXEL tested simply worked.@JJA , can you test that disk in another way?
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
