web interface is unreachable
Hi @LeviPonti,
Can you please share some information with me about this problem?
1- What's the firmware version for your USG210?
2- Do the LAN users can go to internet during you can't access the Web GUI?
3- What do you mean by “ping work normally the request time out” ? Can you please explain? Do you mean you can ping the gateway but sometimes the ping requests timed out?
4- Can you use terminal software to telnet to gateway's Web GUI's port? (For instance telnet to 192.168.1.1:443)
5- Is there any event that triggers this issue?
6- Can you please share your topology with me?
Best regards.
1- V4.62(AAPI.0)
2- no
3- i ping the firewall but the web interface time out
4-I have not tried
5-I don't know...i reboot the firewall and the problem seems solved
6-You mean the network map?0 -
Hi @LeviPonti,
Thank you for your feedback.
Please update to the current release from the following link which should fix certain symptom;
https://www.dropbox.com/s/cjotat52hihnydq/462AAPI0ITS-WK08-r98489.zip?dl=0
In the firewall's Web GUI, find the Local Firmware option from the following path;
Maintenance > File Manager > Firmware Management > Firmware Status > Upgrade
Best regards.
Thanks..is a unofficial firmware ?0
Hi @LeviPonti,
This is an official firmware.
The difference between the formal release and this version is that it contains some fixes that reported by the customers.
Best regards.0
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
