XGS1930-52HP - Layer 3 features supoorted in Nebula Cloud?
Good news! IP interface and static routing will soon be supported in the end of this month, stay tuned.
Sounds great.Are there other features of the XGS1930-52HP which are not supported by Nebula Cloud?dempie
Can you let me know what features you will need?0
e.g. features like ACL, IGMP, unknown mutlicast handling, DHCP server. I know the XGS1930-52HP supports them. But is it true when the switch is managed by Nebula Cloud?One more question:If I purchase one of those switches what happens to my Nebula Cloud account? I fear my account will be degraded to basic if I don't have a pro license in the beginning. The XGS1930 is just Nebula Flex. Or is there a testing period with the switch?Dennis
You can add the switch to your Nebula but it will consume some of your Pro points and it will reduce the co-termination time.
Will support ACL (currently it's just IP based) will support MAC based, soon and IGMP unknown multicast drop but no DHCP server.For your second question, for instance if your org's license point can be used until May, and after you registered one of the switch (without license) then the expired date will be reduce to April since it is the co-termination.
Regarding features: Really great. More than I expected.Second question: My org is lifetime. So I have no Nebula points. Is it possible to test XGS1930 with Nebula Cloud without licensing in the beginning?Dennis
LLL Org. will need the license otherwise you cannot registered the device, but you can still see them in Nebula GUI, those features behavior are same as standalone.0
Is it possible to get a time limited license just for testing to see if managing the switch via Cloud works as expected with all the features I need?dempie
I think you can create another new organization then will have the 30 days trial for you to done the test.
- 216 Nebula Ideas
- 570 USG FLEX H Series
- 342 Security Ideas
- 295 Service & License
- 471 News and Release
