Converting configuration from USG50 to USG200FLEX.
Hello.
How can I convert/migrate the configuration from my old USG50 to my new USG200FLEX. I found the online converter on the Zyxel site, but there is no option to convert the configuration in one step.
What should I do?
Thanks in advance and best regards,
dirsve
hi @dirsve and @Zyxel_Can
If you pay attention and you have a chance to try it, you can convert the existing config file from usg50 to usg60 at https://convert.cloud.zyxel.com/. Then you can try to convert to usgflex200 by deleting the version line inside the config file. Afterwards, you can test the config file by providing controls on the resulting file. But if you have a usg60 device, you will have a much higher chance of success if you freeze the config file with version 4.10 and convert it to 4.62. We switched from a very complex usg300 to atp800 2 weeks ago in a similar application.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
