[NEBULA] Social Login
Dear All.
I am having trouble to configure Social Login..
I think you have to update your guide..
When trying to login in with the facebook like button this happens
So i configured it like the guide you set online
Only difference is the HTTPS option is not to sett off by default
also when adding http redirect URL and then click save i get a error message
This last error must be related on the first error i get when hitting the like button!
Any idea's1
Hi @Vieg, Welcome to our community!
You're right, our FAQ is outdated since Facebook did some upgrade and also the new Nebula phase 3 includes some enhancements for Facebook social login.
So, to solve this issue, you can do the following:
- Turn off Enforce HTTPS (new option for FB APP): currently, our integration only supports HTTP. By turning it off you will solve the error showed while saving. This option is recommended but not mandatory.
- Change the valid OAuth Redirect URIs: part our new phase 3 enhancements is related to the structure of the Facebook social login feature which implies changes in the URL. The new URls to be added have the structure:
"http://nap-slogin.nebula.zyxel.com/CP/THEMEX/fb_userdata.html"
This "X" in the URL makes reference to SSID number that has Facebook social login configure. If you have configured the SSID 1 with Facebook social login:
Then the URL in Facebook APP should be:
"http://nap-slogin.nebula.zyxel.com/CP/THEME1/fb_userdata.html"
If all the 8 SSIDs available on NCC need to use the same Facebook APP, you will need to add 8 URLs
"http://nap-slogin.nebula.zyxel.com/CP/THEME2/fb_userdata.html"
"http://nap-slogin.nebula.zyxel.com/CP/THEME3/fb_userdata.html"
"http://nap-slogin.nebula.zyxel.com/CP/THEME4/fb_userdata.html"
"http://nap-slogin.nebula.zyxel.com/CP/THEME5/fb_userdata.html"
"http://nap-slogin.nebula.zyxel.com/CP/THEME6/fb_userdata.html"
"http://nap-slogin.nebula.zyxel.com/CP/THEME7/fb_userdata.html"
"http://nap-slogin.nebula.zyxel.com/CP/THEME8/fb_userdata.html"
Give it a try and let us know how it goes. We'll update the FAQ soon, thanks for your observation
2 -
Sorry for my late answer this works!
3
- 221 Nebula Ideas
- 615 USG FLEX H Series
- 53 Wireless Ideas
- 483 News and Release
