NWA210-AX and 160Mhz
So I set up a SSID for 5Ghz only, and enabled 160Mhz bandwidth, yet in the Radio settings menu in Nebula, 5Ghz channel width, only 20, 40, & 80 are displayed, even though the AP shows at the bottom of the screen Channel Width 160Mhz. Firmware is V6.10(ABTD.8)
Hi @boing98
We have a tips to remind about the 160MHz only can be supported on specific models and must be configured in the AP list.
The channel-width setting here is for site wide setting. So far, not all models support 160MHz. To avoid mis-configuration from customers' side, we will not list 160MHz here.
If you want to check the 160MHz channel, you can go to AP monitor page to realize the detail.
Joslyn0 -
Joslyn,
As stated in the title, this is in reference to a NWA210AX, which is Wifi6/160Mhz supporting supposedly. I have followed the limited instructions on editing the AP list, and applying 160Mhz, but once applied, it does not show up in the monitor page as 160Mhz.
Here are screen shots:
Showing Model and that 160Mhz is applied:
Showing Model, and that it is up to date and channel spread:
Showing the missing ability for selecting 160Mhz:
Hi @boing98
As I mentioned in previous response, the channel-width setting here is for site wide setting. NCC will push this configuration for all APs in the AP list. So far, not all models support 160MHz. To avoid mis-configuration from customers' side, we will not list 160MHz here.
Joslyn0 -
So where then on a supported model do you implement 160?0
Hi @boing98
So far, NWA210AX, WAX610D, WAX650S support 160MHz.
1. We have to configure the 160MHz in the AP list. Access point > Configure > Radio settings > Access point.
2. It is 160MHz if there are 8 channels.
3. We will implement 160MHz in the channel width list in the future.
Joslyn
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
