How to MOVE Device Site -> Site, Same Organization
ivessm
ivessm Posts: 45 image  Freshman Member
edited April 2021 in Nebula
I'm in INVENTORY and trying to move a number of devices to ANOTHER SITE, same organization.
I check/select the devices and then go to Add to and select the other site to MOVE them to. Nothing ever changes in the list under the sites the devices are assigned to. When I try to leave the ORGANIZATION an error comes up saying the changes have not been saved but there are no SAVE choices on the screen. What's going on?
How can I MOVE a device from one site to another, SAME ORGANIZATION???
Thanks.
-stew
  • ivessm
    edited April 2021
    I finally UNREGISTERED the 20 devices I had to MOVE to the other site and REREGISTERED them under the new site.
    Fort there life off me I could not figure out how to move a device between sites.
    Maybe it will work when the upgrade is posted.
  • Zyxel_Jason
    Zyxel_Jason Posts: 430 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Sales Associate
    Hi @ivessm,
    I have replied you on your another same post.
    Hope it helps.
    Jason
Nebula Tips & Tricks
