random disconnects with NWA1123AC-v2
Hi @Wookie
Thanks for updating the co-work experience with your neighbor. DCS is to let AP auto scan and choose channel, but if you’ve tuned the appropriate channel then it’s fine to use fixed channel.
For the AP’s service coverage, no matter the AP is installed as a ceiling or a wall-mount, the signal behind the AP is the worst position.
Even if it is placed on the ceiling of the first floor, it will not be good to provide it to the device directly above the second floor.
It is recommended to use one AP on each floor, you can deploy as wall-mount if the ceiling is not easy to install.
Regards,
Bella
Hi @Wookie,
The AP installed on the ceiling in first floor, its radio pattern is hard to cover the range of second floor. Although another AP is wall-mounted, we still need to consider the distance and obstacles from the PC to AP. Can you provide their locations?
There are other 5GHz wireless signal in the environment, we suggest you can enable DCS to let AP scan and choose the channel with less interference.
Regards,
Bella
Hi Bellathanks for your quick reply. The PC in the second floor is exactly under the AP which is installed on the ceiling (concrete). The vertical distance is between PC and AP is around 1.5 meters. What I dont understand is that the signal on the PC is around -62dbm to -70dbm and I get around 110 Mbits with a speedtest.Can you tell more about the reason code I posted? I will also try DCS for both APs.Many thanks0
okay, will do that. I configured DCS schedule each morning at 06:00 AM. Do I understand correctly that DCS client aware ( I didnt activate that) would avoid that the APs are looking for new channels if clients are connected? If so, my APs would never check for new channels as I have clients (smart home devices) that are always connected.this is how I configured it:BTW: thanks for your quick and helpful answers, really appreciate that!0
Hi thereI enabled DCS and it made things even more worse, the RSSI dropped by around 4dbm and I had more noise. Going back to fixed channels improved the situation a bit. Fortunately I could take to my neighbour whos Wifi was on 80mhz and on max. power output. He changed the channel width to 40Mhz and also set a fixed channel far away from mine. This improved the rssi by around 5dbm.As of now it seems to work. I am now also aware that the APs are not designed to cover devices above it.RegardsAndrew0
Woolie
You said: "I am now also aware that the APs are not designed to cover devices above it."
I wonder what would happen if u mounted the AP upside down on the ceiling below the PC? Of course it might adversely affect the first floor coverage but curious minds want to know what would happen.
-stew0 -
Hi Stewgood question
actually I think this is quiet difficult as there is no way to install it upside-down. Another possibility would be to install the AP in the first floor upside-down on a sideboard or something like that. Then it may covers the first and second floor.
Hi @Wookie
Regards,
Bella
Duct-Tape...0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
