NBG6515 - 'Obtaining ip address loop'
antenore
in Home Router
After upgrading the firmware to the version V1.00(AAXS.7)C0, with most of my devices, I cannot connect anymore using the DHCP, I've to set the IP address manually.
It happens on Linux and Android with a recent kernel, so far older versions of Linux and Android are still working correctly.
The router config looks good to my eyes.
Before to try to downgrade the firmware to the previous version(s), I'd like to know if it's a known issue and if I can do anything to debug and fix the problem.
Thanks!!
Maybe try a reset?0
Hi,I use Galaxy note 10 +, the mobile can get IP and work correctly.Have you tried to reset device?0
Hi @antenore,
Could you provide which model of the Linux /android base device meet the issue?
You can try to capture the packet and see if there is any DHCP packet related to your device.0 -
Zyxel_Jerry thanks for the answer, I didn't get the notificationI've rolled back to the previous firmware version and now everything is fine.I had to, because I was suffering continuous connection issues, even with a fixed IP address.This happens only with Android 10 and Linux kernel > 5.0.0 as far as I can tell.I need this connection to work (@home), so I cannot debug more the issue, I'm very sorry :-\But tyhe new firmware version has0
Zyxel_Jerry thanks for the answer, I didn't get the notificationI've rolled back to the previous firmware version and now everything is fine.I had to, because I was suffering continuous connection issues, even with a fixed IP address.This happens only with Android 10 and Linux kernel > 5.0.0 as far as I can tell.I need this connection to work (@home), so I cannot debug more the issue, I'm very sorry :-\But the new firmware version has some serious issues in my opinion, again, I'm very sorry I cannot troubleshoot this :-(0
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
