Add Devices - Template Format for MAC Addresses
I have a number of devices to add to a site and have scanned the barcodes for the Item #'s, Serial #'s, and MAC Addresses from the labels on the boxes into a spreadsheet. I then went to add these to the site and downloaded the TEMPLATE devices.xlsx and noted that the format you want for the MAC address is AA:BB:CC:00:11:22 and when I look back at my spreadsheet I see the format of the MAC address is: AABBCC001122.
Okay, so this says I can't go directly from scanning the barcodes into the registration screen or even into a spreadsheet that will be read by the system. I have to ADD the : between the MAC address layout. Really??? Can't you read what is scanned from your barcode? So I created the formula to convert the no : string to a : string. Just another step to get the Nebula.
It seems logical to me that you should be able to read either format, either with : or without :.
Just wanted to bring this up.
-stew
-stew
Hi @ivessm
Good day,
Now we can import TEMPLATE excel with MAC address without ":" and find NCC will add ":" automatically.
Thanks for your suggestion.
Hope you can enjoy Nebula.Zyxel Melen1
Hi @ivessm,
Thanks for sharing this information to us. We did a test is that we import TEMPLATE excel with MAC address without ":" and find NCC won't add ":" automatically.
We will enhance this function and it will be finished in 2021 Q2.
Zyxel Melen0 -
Hi @ivessm
Good day,
- 438 Beta Program
- 189 Nebula Ideas
- 6.2K Security
- 459 USG FLEX H Series
- 304 Security Ideas
- 81 Switch Ideas
- 280 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
