HTTP Traffic Blocked on VPN Connection to USG FLEX 700
Equipment: USG FLEX 700 - Nebula Managed
2 - CISCO ASA devices providing point-to-point VPN connection to remote sites.
I can PING and TRACERT connections to remote devices at the other end of the CISCO ASA's. TRACERT verifies that the packets are being routed over the CISCO ASA VPN's. NOTE: There is no other way to connect to these remote devices except over the CISCO ASA route.
I can NOT get a successful HTTP connection over the same ASA connections to known HTTP devices at the remote ends.
I cannot see anything in the USG FLEX 700 Nebula Management screens that would be blocking HTTP traffic and allowing PING & TRACERT.
The routing in the USG FLEX 700 was setup under: USG FLEX > Configure > Routing > Static Route as eg:
Thanks in advance.
-stew :-)
- Subnet: 10.16.4.0/24
- IP Address: 10.16.24.4 <<This is the local address for the link to the ASA>>
- Metric: 1
- Description: Bla Bla Woof Woof
Thanks in advance.
-stew :-)
So 2 ASA connect the VPN tunnel and what is USG flex playing the role is in this scenario?About static route, the next-hop IP should be the peer site device, ASA IP is 10.16.24.4 ?
Chris, thanks for commenting. Yes,the link to one local ASA is IP 10.15.24.4 and the other is 10.16.24.6
Both of these pass PING traffic but neither of them pass HTTP traffic. I can't figure out why.
-stew0 -
The USG FLEX 700 is the site router. It handles all routing between the internet and the 2 VPN/ASA devices.0
I switched the USG FLEX 700 over to Console Management yesterday. Reconfiguring and will report when I have findings.
-stew
Nebula_Chris, yes, I removed the USGFLEX 700 from NEBULA Management and brought it up as CONSOLE management.
Just my opinion but there are far more options for a device like the USGFLEX 700 under CONSOLE MANAGEMENT than NEBULA MANAGEMENT.0 -
@ivessm ,Understand but the advantage of Nebula management is easy to configure the setting (simplify the UI) and most important thing is it has provide the centralized view of network activities also the admin user management grouping (teams) is another pros.
Chris, I hear what your saying and I totally understand but I ran into too many limitations on the NEBULA managment of the USG 700 than the straight CONSOLE Mgmt. Case in point... Where can I see the attached in NEBULA that is available in CONSOLE Mgmt under Configuration > Security Policy > Policy Control???
I would really really appreciate it if you could point that out to me. Believe me, I looked and looked.
Here it is from CONSOLE Mgmt.
Thanks.
-stew
You can configure the security policy in USG FLEX>Firewall, Security policy.In order to prevent the user block the device connection from server by accident therefore we have hide the default rules.
- 438 Beta Program
- 189 Nebula Ideas
- 6.2K Security
- 459 USG FLEX H Series
- 304 Security Ideas
- 81 Switch Ideas
- 280 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
