PVLAN
Hi @CCVO,
Welcome to Zyxel Community!
Regarding the scenario, I assume that your goal is to avoid the 4 PCs to communicate to each other, and could communicate with VPN100 and 3x servers only, if this is the case, you may configure port isolation to achieve the goal.
Steps:
1. Advance application > VLAN > VLAN configuration > VLAN port setup
2. Check the "Isolation" box where the PCs are connected, and click "Apply" button.
Note: Remember to click "Save" after changing configuration
Hope it helps.
JonasJonas,0 -
thank you0
- 220 Nebula Ideas
- 607 USG FLEX H Series
- 482 News and Release
