I want to switch devices between 2,4 and 5 Ghz without separating the SSID's
Zed
I have Zyxel Multy 3-pack Mesh. My Chromecast has automatically connected to the 5Ghz network and I'm wondering if there is a way to change that in the app? A way to chose which frequency band to connect to without separating the two SSID's.
Thanks in advance
Thanks in advance
Hi @Zed
Currently, Multy device support using different SSID on 2.4G and 5G, but not available to select a specific band on Multy APP.
May I know what scenario you would like to set up in your environment?
I want to connect my Chromecast to 2,4 because it’s disconnecting a lot while connected to the 5 bandwidth. While waiting for reply here I separated both bandwidths and connected the Chromecast to 2,4 but it still disconnected so I assumed there’s something wrong with the Chromecast itself. Or is there maybe documented cases of this Zyxel system being unstable with Chromecast? Thanks for your replyZyxel_Jerry said:Hi @Zed
May I know what scenario you would like to set up in your environment?0 -
Hi @Zed
Could other clients connect to the Multy device?
To check the signal in your environment, you can download the wifi analyzer on your mobile and use the app to check.
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
