NAS326 HTTP Stopped after cert upgrade
Skippy
I went to update the certificate for secure communications and the NAS 326 no longer is working with the web client. I am able to SSH in to the box, but unable to find the reset script. So I either need to reset the box from the CLI or fix the HTTP to work with the certificates. Any thoughts on this process ?
Oh and I noticed that the zyxel_xmpp_cl is making some connection to amazonaws which I know we don't use AWS.
Thank you in advance
how did you update the certificate?
you can try find command if you know the name of the script
find / -iname "script"
or maybe try reboot the machine?
by the way how did you find zyxel_xmpp_cl is communicating with aws?
can you share screenshot or command for that?
soul said:how did you update the certificate? (Skippy) I used the webgui initially then the server gave a 504 error after submitting a FQDN certificate from Comodo, then afterwards the web server quit working unable to start it from the command line didn't work either.
find / -iname "script" (Skippy) Yes and I have tried grep -irn 'pattern' / nothing tangible in the results.
or maybe try reboot the machine? (Skippy) System was rebooted a couple of times.
by the way how did you find zyxel_xmpp_cl is communicating with aws? (Skippy) I am logged in the shell using SSH then performed a netstat.
here's a forum topic about certificates
https://community.zyxel.com/en/discussion/8527/nas326-install-ssl-certificate-via-scp
in the nas i found this path it may help you. looks like "reset_and_reboot.sh" is useful for you.
aws should be related to myzyxelcloud service on nas.0 -
Ok so now I am unable to SSH in to the box, I went to do a factory reset, heard the 3 beeps and the system rebooted. What does a factory reset do ? Since I am unable to gain access to this unit I purchased 3 months ago what options do I have?0
Is your NAS getting IP address?
You can try NAS Starter Utility that may help you
https://www.zyxel.com/support/download_landing/product/nas326_19.shtml?c=gb&l=en&pid=20150327120001&tab=Software&pname=NAS326
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 908 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
