LTE firmware for SBG3600
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,538  Zyxel Employee
    Hi @systemchecker ,@Mikko,
    Firmware provided via private message, please have a check.
  • Mikko
    Mikko Posts: 2  Freshman Member
    Guys, does the Cooldia's sent file work for you? For me it's not installing although I know what I'm doing. Any ideas?
  • Zyxel_Cooldia
    Hi @Mikko,
    The upgrade procedure is same as your private message description,  after you upgrade the LTE firmware , you should be able to see the log as below,
    Got image via http, total image size: 5191332
    Start upgrade module firmware   0rilcmd:error:195.710:convert_binary_to_ascii:2242:
    Start upgrade module firmware   0%
    rilcmd:error:199.743:convert_binary_to_ascii:2291:      1%
    rilcmd:error:203.768:convert_binary_to_ascii:2291:       3%
    rilcmd:error:394.098:convert_binary_to_ascii:2291:    100%
    Convert time: 3 min 18 sec
    rilcmd:error:394.100:convert_binary_to_ascii:2301:
    Reboot the system ...rilcmd:error:395.146:convert_binary_to_ascii:2317:
    It supposed to reboot the system when it run to 100%
    Do you have console log for analysis?
  • Jone
    Jone Posts: 2  Freshman Member
    I'm suffering of poor performance and would like the updated FW as well. BTW the the latest router firmware (AAKO.8) is missing release notes - any chance of getting those as well?
  • Zyxel_Cooldia
    Hi @Jone,
    We can download the firmware release note from Zyxel download library.
    Here is the download link,
    ftp://ftp.zyxel.com/SBG3600-N000/firmware/SBG3600-N000_1.00(AAKO.8)C0_2.pdf
  • Jone
    @Zyxel_Cooldia thanks, may I have the updated LTE firmware as well?
  • Zyxel_Cooldia
    Hi @Jone,
    Sure :) , Firmware provided via private message, please have a check.
  • Markyus
    Markyus Posts: 1  Freshman Member
    Hello! Can i have also newest firmware for LTE upgrade
  • Zyxel_Cooldia
  • yordanoglou
    yordanoglou Posts: 2  Freshman Member
    Hi @Zyxel_Cooldia
    Regard
