Multiple S2S VPNs with AWS can't established after internet break
124»
  • gb5102
    gb5102 Posts: 25
    It appears you already figured out your issue, but I just wanted to point out that DH groups 16 thru 18 have known issues, I believe it started in v4.39.
    From firmware release notes:
    IKE v2 Proposal mix not working (DH16, DH17, DH18)
  • Zyxel_Can
    Zyxel_Can Posts: 342
    25 Answers First Comment Friend Collector
    Hi @gb5102,
    Thank you for your comment.
    All of the firmwares after v4.62 covers IKE v2 Proposal mix not working (DH16, DH17, DH18) fix.
  • Wojtas
    Wojtas Posts: 49
    edited July 2021
    Hi @Zyxel_Can
    Maybe you fixed the DH group issue, but the devices are too slow for this. When tunnels had been negotiated, the GUI was very slow and showed a lot of CLI errors, CPU worked on 90%... and that's why tunnels hadn't been established.
  • Ian31
    Ian31 Posts: 165
    5 Answers First Comment Friend Collector Fifth Anniversary
    DH19(ECP256), DH20(ECP384) is support by Azure. (DH21 is not support)
    It's an alternative to DH16,17,18 with same security strength but fast.
  • gb5102
    gb5102 Posts: 25
    Zyxel_Can said:
    Hi @gb5102,
    Are you saying the known issues with DH16/17/18 are fixed in current firmware versions?
    Because this issue is still listed under "Known Issues" section in v4.65 release notes for Zywall 110.
  • Zyxel_Can
    Hi @gb5102,
    Sorry for misunderstanding.
    The fix was actually implemented in the forum release version.
    Currently the latest forum release version is 4.62 WK14:
    https://community.zyxel.com/en/discussion/10639/zld-v4-62-wk14-firmware-release#latest
    The 4.65 forum release will be ready next week.
    You can download the latest updates from the following thread once it was released:
    https://community.zyxel.com/en/categories/firmware-release
Security Highlight
