USG Flex 200 not allowing Youtube to fully load, error is You're offline. Check your connection.
laltobelli
in Security
I'm using a USG Flex 200, I have disabled all Security Policies. When accessing www.youtube.com I get the message "You're offline. Check your connection." and only part of the page loads. See attachment. The videos do flash briefly but then disappear. All other sites seem to work ok. Nothing appears in the log files regarding youtube.
Larry
Larry
In addition I did update the firmware which may have fixed this and a couple of other issues I was seeing.
Not too sure what happened. On Friday no PC on site could access Youtube through the Zyxel. They could only access it if tied to their phone's hotspot. Today there does not seem to be a problem accessing Youtube.
im having same issue on usgflex100... what is the resolution?0
I've just upgraded to flex 100 from older usg series.
Ever since, I'm having the same error described here. Some traffics are routed to another usg 20, but same.
I have flushed local dns cache, internal dns server cache numerous times. Youtube worked briefly when I restarted entire network.
Is there any other setting I should touch? My firmware is the latest as of today.0 -
See if blocking UDP 443 from LAN to WAN does anything.0
Strange, how's the result when using terminal and ping to www.youtube.com? And had you turned on any kind of utm features (content filter, as, reputation filter...etc). You can also check if the log says anything related to blocking.0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
