Bundle Pro Licenc activation
Hi @baldrian,
Thanks for your help.
I have checked your organization and there is only WAC6552D-S having license, other APs and Switch don't have license.
As I mentioned, your organization need to have enough license for all devices to upgrade to Pro Pack and activate license.
Please register and assign NCC Pro license for your other Nebula devices.
Hope it helps.0
Has no one an idea how i can activate this Licence?0
Hi @baldrian,
Welcome to Zyxel Community!
If your organization has enough license to upgrade to Pro Pack, you may go to Organization-wide > Configure > License & inventory > Overview to upgrade.
After upgrading, the license will activate.
If there is still having problem, please help to enable Zyxel Support at Help > Support request page and share your organization name, so we can access to check.
Thanks.
Hallo Jason, thank you for your help. I have activated the invite. My Organisation Name is Schloss.
Best Regards.0 -
Hello Jason, Thanks for your help, So it means i need an Licence for every device and not one licence for all devices. It was my missunderstood.
What for an Licence can i buy that i can administrate all devices with all features?
Kind regards0 -
Hi @baldrian,
For AP and Switch, you need to buy NCC Pro Pack license to have full feature.
You may refer to the following link to understand difference between license Packs and our License 2.0 overview.
Nebula Control Center NCC - Subscribe Nebula | Zyxel
Nebula License 2.0 Overview | Zyxel
Hope it helps.0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
