Mac address filtering on ATP/USG
DiegoF
it would be very useful to be able to create security policies based on mac address objects. In Zyxel firewall there is no possibility to create mac address objects like in other vendors firewall. Is this a feature you plan to implement on your firewalls as well?
2
Why not use a switch?
Hi, i'm looking for the same issue.. I need to create mac address filter on dhcp, so only authorized MAC address can connect to the lan...
- 441 Beta Program
- 293 Service & License
- 461 News and Release
ZCNE Certified
