Config WDS correctly for VMG1312-B10B (WAN by WiFi)
MarceloP
Good day
I have been testing many options to be able to use the VMG1312-B10B as a WIFI repeater using WDS service.
In my house I have internet connectivity with a cable modem SAGEMCOM FAST 3686. I want to connect the VMG1312 via wifi with the SAGEMCOM
to be able to extend internet access in the garden of my house.
I can not connect them via ethernet cable because I can not wire in the garden. That's why I want to link them with wifi.
I will appreciate if you can help me. Thank you.
Buen Dia
He estado probando muchas opciones para poder utilizar el VMG1312-B10B como repetidor WIFI usando el servicio WDS.
En mi casa tengo conectividad a internet con un cablemodem SAGEMCOM FAST 3686. yo quiero conectar el VMG1312 via wifi con el SAGEMCOM
para poder extender el acceso a internet en el jardin de mi casa.
No puedo conectarlos via cable ethernet porque no puedo cablear en el jardin. Por eso quiero vincularlos por wifi.
Agradeceré me puedan ayudar. Gracias.
#CPE_Jan_2019
#CPE_Jan_2019
Marcello hello,i am trying to do the same. have you managed to set it up?0
I have looked in the VMG1312-B10B manual available at https://fccid.io/ANATEL/00961-15-08311/Manual-VMG1312-B10B/4940CDA4-168E-48CF-B6BA-80681CFA7188/PDF dated 2013 and section 7.7 says how to use WDS.The manual has a note in it that says:"Note: At the time of writing, WDS is compatible with other ZyXEL APs only. Not all models
support WDS links. Check your other AP’s documentation."I have not got one to try myself to prove that it works.You could use a WiFi extender from Zyxel, such as WRE2205 see https://mysupport.zyxel.com/hc/en-us/articles/360003389460--Repeater-How-to-configure-the-WRE2205-v2-for-the-first-time and https://www.amazon.com/ZyXEL-Wireless-300Mbps-Extender-WRE2205/dp/B008XAZHN4 , or WRE6505 see https://support.zyxel.eu/hc/en-us/articles/360001390834-How-to-setup-a-WRE6505-as-a-Repeater-via-Wizard-Mode or one from another manufacturer.- I personally use TP-Link RE300 WiFi Range Extender connected to my Zyxel VMG1312-B10D.Kind regards,Tony
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 299 Service & License
- 482 News and Release
