How to activate response to Ping from NSG50
Hi @Oxygen,
Welcome to Zyxel Community!
You may go to Security gateway > Configure > Firewall page to specify your allowed IPs for Ping.
Feel free to let me know if you have any concern.
Adam0 -
Hi Adam,
The configuration is already ok but it doesn't work ?0 -
@Oxygen,
May you help me to enable Zyxel support at HELP > Support request page and provide me your organization name so that I will have privilege to check your issue.
Thanks,Adam0 -
Done...
organisation OXYGEN / LES ULIS0 -
@Oxygen,
Thanks for your reply.
Sorry, I just see that your issue is your client is unable to ping to LAN2, and I notice that you enable LAN 2 as Guest interface.
It will make client under this 192.168.91.0/24 subnet unable to ping 192.168.91.1
Hope it helps,Adam0 -
It works thanks a lot
What's the meaning of guest ?0 -
@Oxygen,
I have to rephrase my words that enable Guest feature on LAN interface makes devices have ability to access Internet but cannot communicate to other LAN devices; however, devices on other LANs are able to communicate to devices under LAN interface with Guest enabled.
Adam0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
