How to activate response to Ping from NSG50
Hi @Oxygen,
Welcome to Zyxel Community!
You may go to Security gateway > Configure > Firewall page to specify your allowed IPs for Ping.
Feel free to let me know if you have any concern.
Adam0 -
Hi Adam,
The configuration is already ok but it doesn't work ?0 -
@Oxygen,
May you help me to enable Zyxel support at HELP > Support request page and provide me your organization name so that I will have privilege to check your issue.
Thanks,Adam0 -
Done...
organisation OXYGEN / LES ULIS0 -
@Oxygen,
Thanks for your reply.
Sorry, I just see that your issue is your client is unable to ping to LAN2, and I notice that you enable LAN 2 as Guest interface.
It will make client under this 192.168.91.0/24 subnet unable to ping 192.168.91.1
Hope it helps,Adam0 -
It works thanks a lot
What's the meaning of guest ?0 -
@Oxygen,
I have to rephrase my words that enable Guest feature on LAN interface makes devices have ability to access Internet but cannot communicate to other LAN devices; however, devices on other LANs are able to communicate to devices under LAN interface with Guest enabled.
Adam0
- 397 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 91 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 918 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 920 Nebula FAQ
- 422 Security FAQ
- 237 Switch FAQ
- 208 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
