DHCP on VLAN for Guest Wifi does work
chr_sergey
I configured on my USG FLEX 200 2 SSID (via WebInterface)
WLAN STAFF - VLAN-ID 1 (default)
WLAN GUEST - VLAN-ID 17
USG FLEX 200 connected to GS2220-50 on port 44.
GS2220-50 connected to GS2210-48 on port 41.
Two access points WAC 6103D connected to GS2220-50 on ports 3 and 4.
Now I am facing the problem, that I can connect to "WLAN_guest" but get an APIPA adress, the DHCP does not provide an 192.168.50.0 address and I have no clue why....
Any ideas what I fail to see here?
May be need configure VLAN on SW GS2220-50 and GS2210-48?
How configure vlan17 on GS2220-50 and GS2210-48 for Guest ssid?
Hi @chr_sergey,
Here is a scenario for reference setup :
1- Configure switch’s ports as fixed and Tagged:
2-Create VLAN17 in your USG FLEX 200 (Configuration > Interface > VLAN > Add)
3- Create security profile (Configuration > Object > AP Profile > SSID > Security List)
4- Create SSID profile (Configuration > Object > AP Profile > SSID > SSID List)
5- If you have managed AP, add into Mgmt list (Configuration > Wireless > AP Management > Mgnt. AP List > AP List)
6- Create AP Group Profile (Configuration > Wireless > AP Management > AP Group)
7-Add AP into list
Here is the related KB for this scenario for your reference:
https://kb.zyxel.com/KB/searchArticle!viewDetail.action?articleOid=017406&lang=EN
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
