How can i backup running config in a switch using ssh script?
I want to make backups from my switch configs, and i want to use an ubuntu machine with cron for this task, so i can automate it.
My switch is a XGS1930-28HP with firmware version 4.5(ABHS 7.1)
I want to use this command in my script to ssh to the switch:
sshpass -p "password" ssh -o StrictHostKeyChecking=no admin@SWITCH_IP COMMAND
My command would be show run, and then i wopuld capture it, and save it a in file.. but i cant use any command with this, because when i try to use it, the switch return me this error:
Received disconnect from SWITCH_IP port 22:2: invalid command run.
Disconnected from SWITCH_IP port 22
So, please help me, how can i automate taking backup from my switch configs?
Thanks.
Thanks.
You put "show run" between quotes?
Just saw another post also about this and seems having workaround there.
https://community.zyxel.com/en/discussion/3401/gs1920-24hpv2-non-interactive-ssh-invalid-command
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
