Shell access to C3000Z
josepha11
I use C3000Z Router which has firmware version CZD005-4.16.011.0
I enabled Remote Console LAN SSH and able to login form my LAN PC ssh to 192.168.0.1
When I type sh, it ask type the Shell Password.
I am not aware of it. anyone pls help how to get shell prompt. Thanks.
#SP_Oct_2019
#SP_Oct_2019
You set the user name and password in the C3000Z web interface when you enable remote access *ssh*
@tryingC3000Z the username and password you set with the web interface is not the same one you need when the router asks "Please input shell password". This only happens when you ssh to the router, then type the "sh" command. This used to be open, but has been locked down since 2019 it seems.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
