NAS542
Sieben
Hi all.
I have a major problem I hope you can help me with.
In my NAS I have 4 harddrives (2TB, 3TB, 10TB and 12TB). All in Raid BASIC.
For some reasend all my files was saved on the 12TB drive and nothing on the others.
Now I have changed the 3 empty drives to JBOD and they apear now as one drive on 15TB.
My question are: How do I change the drive with all the files to JBOD without loosing the files.
I have tryid to connect it to my computer but Windows don't see it.
I also tryid to connect it as externel drive without any luck.
Anyone who can help a noop.
Looks like you misconfigured your volumes. I assume you enabled your NAS's SSH.
First SSH to your NAS and find /i-data/ path. Execute ls and find your volume names, then execute this command to move content first
mv /i-data/sysvol/* /i-data/targetVolumeID/
After that remove the hard drive with the files and create your volume again. But this time create RAID5 with 3 drives (12TB, 10TB and 3TB). Using basic raid or JBOD is not a good idea.
Move the files back again to your RAID volume
mv /i-data/previousVolumeID/* /i-data/sysvol/
Sapphire23. Thank's for your answer, but I got it yesterday. After I had been fidling with the 3 small drives, I found where I could add the files from the large drive so that I could see them in Windows. So now I'm copying the files to the small drives. After that I will format the big drive into (against your warning
) JBOD. 0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 908 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
